08 f250 10" fabtech lift but need more - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-22-2010, 06:04 AM Thread Starter
I have a 2008 f250 crewcab that has a 10" fabtech lift, that was done before I bought it. Its fabtech basic kit with just the drop brackets for the front arms. It does have new springs in the rear so its just using the factory block with the bump stop plus a small 1" block. At the dealership where I bought it the tires and wheels were stolen so they put a new set of 40" toyos on it for me. Now the tires will hit the front fenders when you have it turned and hit a good bump. So its time to go bigger which was my plan anyways thats why I went with the 40"s . I am in the process of doing the hydro assist steering. For the back I was just planning on changing the blocks to the OUO blocks with the traction bar built on. Im not sure what to do to the front to get more height. Any suggestions anyone ? Really only want to go another 2"s or so.
thanks in advance.
I will try to get some pictures of what I have right now
reefpatrol is offline
post #2 of 8 Old 02-22-2010, 06:12 AM
Jason.'s Avatar
Quoted: 12 Post(s)
Send a message via AIM to Jason.
2 cheap options for the front.
1. Get some new coil springs that are 2" taller than the ones you have.
2. Put a 2.5" spacer under the springs.
Truck- 15 F-250 CC SBPlatinum 4x4 6.7 powerstroke. 2.5" Pro Comp leveling kit, 35" Toyo M/T, No Limit stg2 intake, No Limit EGR delete, FlowPRO 5" full exhaust w/6" tip, SCT x4 w/gearhead tunes, Edge CTS2, No Limit upgraded intercooler piping.
Toy - 15 Robalo 226 Cayman bay boat "Shallow Minded". 200hp Yamaha 4 stroke with command link/fly by wire, atlas jack plate, power pole, minn kota #80 ipilot, simrad nss7 evo2 with structure scan.
Jason. is offline
post #3 of 8 Old 02-22-2010, 06:49 AM Thread Starter
who makes taller coil springs?
the tallest I can can find is the 10" ones
post #4 of 8 Old 02-22-2010, 06:54 AM
Pahrump's Avatar
Coilovers...IMO the best way. If you have all the other stuff then you could do this for $1500 or less....Kings or Fox and Rize mounts. 16" travel is what you need for 10-14" lift
People are going to jump in and say the steering is a problem on these trucks...well not really...have a custom drag link made up with heims on each end...a solid bar, no joint like the stocker.
And if your feeling froggy flip the track bar over so it mounts on top of the axle and not the bottom as stock.
2008 F250 FX4 CC SB Black on Black STOCK and SLOW...Rolled over and TOTALED...
2008 White with Black interior FX4 CCSB
Black C6 Vette
As far as actual HP numbers I have no idea. It don't snap your neck but.....It feels good.
Pahrump is offline
post #5 of 8 Old 02-22-2010, 06:56 AM
Jason.'s Avatar
Quoted: 12 Post(s)
Well I'm a leafspring guy myself so I'm not too smart on coil springs, but I'm guessing Rize would make one, but you may have to get a full coilover.
If it was me, I'd get a 2.5" spring spacer.
Jason. is offline
post #6 of 8 Old 02-22-2010, 06:59 AM
Lbs
Lbs's Avatar
Listen to this man right here, he gave me some good knowledge a while back that I'll be using for sure!
2006 F-250 PSD King Ranch ccsb FX4 - 14" Lift w/ TGC 4-Link, Fox 2.0 Resi's, ARP's, EGR deleted, Cat ELC, Mishimoto Radiator/Intercooler, 4" TB exhaust/6" Tip, SCT w/ IDP & Gearhead Tunes, MO962's w/ 43" Goodyears
Rock Crawler/Trails Rig: 94 Jeep YJ - 12" lift, 1 tons, LS1, 40" boggers... F&R 4-link, coilovers and a 4BT soon
Lbs is offline
post #7 of 8 Old 02-22-2010, 03:44 PM Thread Starter
Do I have to change to the new drag link ?
And will I be able to keep my factory radius arms witht he lower brackets like I have now ?
thanks again
post #8 of 8 Old 02-23-2010, 07:11 AM
Lbs
Lbs's Avatar
If you'd like your drag link to survive, it would be a great idea to upgrade. Now about the radius arms, that's something you'll have to look at and decide after its lifted. You may or may not need a 4-link. Don't forget about shocks, brake lines and drive shafts.
Lbs is offline
