Front End Vibration
I had a horrible vibration in the front end at around 40-50 mph that I'm assuming is what people call the "Death Wobble." It would also dive to the driver's side when hitting the brakes with a decent amount of pressure. I changed out the front shocks, and the vibration calmed down, but it is still horrible when you hit the brakes.
The driver's side rotor has some grooves in it, the fins are rusted, and looks like some fins might be broken. Same condition of the passenger side rotor, except it doesn't have any grooves in it. Could it be the brakes causing all this? I'm thinking about changing the rotors and pads out to fix the problem. Does anyone have any other suggestions?
need more info man.. something like what truck you have would help out a lot
Sorry about that, I thought I had my signature set up already
I've got a 2006 F-250 FX4, Leveling Kit with 35.5" tires. I will jack the truck up and check the ball joints. If you have any other suggestions, please throw them at me.
mine does the same thing the dealer told me that it was the ball joints and the hub assembly. they wanted 1300 for the repair. i told them id do it myself but thanks anyway. does yours "smooth" out after you get @ like 60+
mine dose it i only have 5k on the truck its a 2010, i hope when i lift it my steering stabilizer will fix it it feels like front wheel hop on mine, it will only do it at 50-55mph anything below or abrove its fine
you might wanna take it and get it looked at before you do the lift and tires if it is a problem and you are still stock the dealer should warranty it being it only has 5k miles
Mine does smooth out above 55 & below 45 mph. I'm going to try a new steering damper, and see if that helps. I checked the ball joints and the tie rod ends. There is just a little play on the tie rod, but the ball joint seems to be tight as can be. I got the braking to calm down with a new rotor, but the death wobble is still here. Hopefully I can get rid of it soon.
this is true but then i would have to put my dpf back on
I found this article, and although it does not specifically talk about the Superduty, it does make perfect sense. As an engineer, I deal with this all time, just never with a truck. I guess my tires are just too big with the wheel offset that I have. I will have to make some adjustments somewhere. I'll let you know how it works out. Here is the web site if you feel like reading.
Why Steering Stabilizers? |
just an update i got my front end checked out by a very reputable front end guy back home. he couldnt find ANYTHING wrong with the front end on my truck ball joints, tie rod ends, hub assembly everything was fine. but i still have the bad 40-50 mph "SHIMMY" on the front left. so i take it back to the wheel and tire shop i got my tires from to have them check it out. turns out the wheel weights were messed up and that wheel was out of balance. they rebalanced it and it runs smooth as silk again.. It really burns me up thinking about how that ford dealer tried to bury it in my A$$. i know everyone is out to make money these days but damn.
