What the hell is this bar called? - Ford Powerstroke Diesel Forum
Old 02-15-2010, 06:49 AM
The one circled in black.
My front end has a knock when I steer now, and this bar is loose.
Old 02-15-2010, 06:53 AM
Drag bar I believe is one term.
The tie rod
Old 02-15-2010, 06:56 AM
The tie rod
Old 02-15-2010, 08:45 AM
Lbs Lbs is offline
Tie Rod, the tie rod ends connect to it.
Old 02-15-2010, 08:46 AM
Its got some play in it. What should I do?
Old 02-15-2010, 08:54 AM
tighten the tie rods on the end if im not mistaken they work like a turnbuckle and screw in and out
Old 02-15-2010, 08:57 AM
Almostdunfukinwidit
If thats loose you have a tie rod end or two that needs replacing. Take it in for an alignment
What u talkin bout willis
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
yea do that if you want your alignment off!!!
that is a draglink the tie rods are on the end of it do you have play in the joint part where the tie rod connects to the steering knuckle? or is it actually in the threaded part of the draglink
Old 02-15-2010, 09:09 AM
Berm Buster
O you dont need that bar. Just take it out, your truck will prolly handle better.
