How will my 350 look w/ 2'' leveling kit - Ford Powerstroke Diesel Forum
Old 02-14-2010, 07:44 PM
In a week or 2 I am probably going to order a 2'' leveling kit (Ford Superduty 99-04 Leveling Kit - Sky's Off-road Design). Will my truck look bad with the 31s on it? I am thinking I level it and leave these tires on til its time for 35s. Will it look right? or should I hold off? While I'm asking questions, would it work to use those drop brackets and then later put 2.5'' lift leafs on with them? would that work out to 4.5'' of lift? Looking forward to wisdom.
Old 02-14-2010, 08:04 PM
BGJ BGJ is offline
It'll look just like it does in the rear. GREAT!!!
Old 02-15-2010, 07:30 AM
Feedback Score: 5 reviews
Yes later you can add spring's to get to 4.5". You will need longer shocks now and a adj track bar..later you also may need longer shocks along with sway bar links and a drop pitman arm etc.
