Pitman Arm Help!!!!! - Ford Powerstroke Diesel Forum
Old 02-11-2010, 09:06 AM
middle of the lift and i am stuck on the pitman arm. have a puller set and it doesnt fit i have the drag link off so it is just the arm now. how can you get it off with out using the 130$ tool from sears. thanks need help now
Old 02-11-2010, 09:18 AM
Torching hell out of it will help a bit. Have you tried that yet?
Old 02-11-2010, 10:04 AM
Lbs Lbs is offline
I wouldn't recommend torching it. Its way to close to the steering box, lots of stuff in there that shouldn't be heated up.
Old 02-11-2010, 01:48 PM
Feedback Score: 5 reviews
You can rent them from a auto store.
Old 02-11-2010, 01:52 PM
Definatley would not heat it!! you can get pickle forks fairly cheap. Had to use on mine. downfall is you have to hit the pickle fork with a hammer (manual tools) Huge pain but it usually will do the trick
Old 02-22-2010, 04:19 AM
I tried 2 or 3 pullers we had around the shop that were supposed to work,,,found 1 at Harbor Freight for something like 18 bucks that fits/works great.
Old 02-23-2010, 06:04 AM
You can rent pullers from the auto part stores for free. Don't heat because you will probably ruin an seal and a leaking shaft sucks.
Old 02-23-2010, 06:56 AM
Yea, I've heard girls really hate leaky shafts
Old 02-23-2010, 07:15 AM
Lbs Lbs is offline
Girls are gonna love you for the nice lifted truck, but when they see the leaky shaft its game over
Old 02-23-2010, 08:28 PM
have you tried a heavy duty gear puller?
