Early 99 Lift vs. 99-04 Lift - Ford Powerstroke Diesel Forum
post #1 of 10 Old 02-08-2010, 02:28 PM Thread Starter
Bad Night's Avatar
Quoted: 3 Post(s)
Anyone know the difference in an early 99 and a 99-04 Lift kit . If I were to buy a used 99-04 lift for my early 99 what could I use and what won't work . I'm told it's just the "box kit" that is different but I don't know what that is referring to . Thanks in advance .
07 F-250 Outlaw , Rough Country 6 inch lift , 37-13.5 R20 Nitto Mud Grapplers , MBRP 5" Exhaust , 08 Mirrors , S&B intake , 5% Tint sides and back , 35% windshield .
Bad Night is offline
post #2 of 10 Old 02-08-2010, 02:34 PM
eric99f250's Avatar
well if you have a dually and your buying one off of a single wheeled truck its not going to work the axles are bigger on the duallys i mean yes you could make it work my getting new ubolts i think the trac bars and different and theres something else i cant think of it at the moment someone else will get to you soon with it but thats all the info i have for ya
2000 F350 CC Dually--sold
looking for a new truck
eric99f250 is offline
post #3 of 10 Old 02-08-2010, 02:56 PM Thread Starter
Bad Night's Avatar
Quoted: 3 Post(s)
Yea it's a dually , That sounds easy to adress . Any thing else anyone knows of .
post #4 of 10 Old 02-09-2010, 11:11 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Just the track bar bolt sizes..How high are you trying to go?
CT Performance, Inc. is offline
post #5 of 10 Old 02-09-2010, 02:28 PM Thread Starter
Bad Night's Avatar
Quoted: 3 Post(s)
Was looking to go at least 4 but up to prob. 8
post #6 of 10 Old 02-10-2010, 12:12 PM
Slick02's Avatar
Actually the difference is in the pitman arm spline/hole size, the early 99 had a smaller steering shaft than late 99 and newer,,,,ask me how I know,,,did it on a customers truck and then had to make a service call 50 miles up the road to change the pitman arm (it was cheaper than me having to send a wrecker).
08 F350 Lariat SWB 4x4
Spartan tunes (120 & 210)
Pro Flo DPF/cat delete 4" syst/with muffler
AFE stage II intake
2 1/2" leveling kit/Icon adj track rod
Rancho 9000 shocks
Autopage alarm/remote start
Clarion MAX675VDII/800 watt amp and 10" sub
SS black chrome side vent screens
MotoMetal 951's with Toyo 325/60R20 A/T's
Bushwacker flares/painted to match trim
Harley grille
More to come(cause I can't ever leave well enough alone)
Slick02 is offline
post #7 of 10 Old 02-10-2010, 02:09 PM Thread Starter
Bad Night's Avatar
Quoted: 3 Post(s)
Ok well that helps a bunch . I can buy about any kit and just get the correct pitman arm .
post #8 of 10 Old 02-10-2010, 02:15 PM
Quoted: 3 Post(s)
Yes. Or just order the correct kit if your buying new.
post #9 of 10 Old 02-10-2010, 02:48 PM Thread Starter
Bad Night's Avatar
Quoted: 3 Post(s)
Yea , I will order the right kit if I buy new . Kinda kicking everything around right now .
post #10 of 10 Old 02-12-2010, 08:55 AM
DCSpecial's Avatar
Pitman arm and trac bar brackets are different on the Early 99s as mentioned. Also 99s use square front u-bolts vs. rounded on the 00-04 (but you should use new u-bolts either way on used kits).
DCSpecial is offline
