leaf rubbing issues
rubs the pass side leaf, when i crank hard to the right
doesnt rub when i crank hard to the left.. its minor rubbing and i think 1/2" spacer might cure this problem..are spacers dangerous and unsafe? i still need to get my allignment done.. maybe my camber/toe is out ![]() i have a SFA 2000 f250 with a 4.5" DR/ICON lift, with 35"toyo A/T, 20" moto metal (4.75backspacing, -18 offset) ive heard just to adjust my bump stops to limit my steering but id much rather not do that.. |
With the lift you list in your sig I would say it is an alignment issue.
thanks alot
4.5 lift should clear 35's no problem, plus the wheels have a pretty wide stance already so i wouldnt think i would have this problem. |
bump if anyone has more info
Check that the axle is centered, you still may need a adj track bar.
id say that the axel is shifted to one side or the other
