Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 11-06-2009, 06:36 PM
LIEBHERR622 LIEBHERR622 is offline
03 powerstroke w/6" LIFT problems
I have a 03 powerstroke f250 that just had a 6" lift put on with 37" tires on 17" rims. It feels loose in the rearend like it wants to sway in the road. Is this typical because of the lift or is there something else I can do to it? Thanks!
Old 11-06-2009, 08:09 PM
daboostcreep daboostcreep is offline
Check these things:
Tire Pressure (35-40lbs ??)
Ubolts Super Tight? (They should be.)
Was the rear lift a single block, stock + add on block, or all spring? (Blocks pronounce axle movement, stacked blocks more so)
