- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
The center bolt on the spring pack keeps them together. Jack the truck up and put jack stands under the frame, place a jack under the axle to hold the tension off of it, cut the old ubolts off, slowly lower the rear axle until you have enough room to remove the old blocks and install the new ones. Lift the axle back in place (there should be a guide where the center bolt rides in the block to keep it aligned), install the new ubolts and torque them to specs and you are done. Not too hard should only take an hour give or take. Never reuse the old ubolts though, they stretch and will never tighten properly again.
| Sponsored Links |
What do you guys think about these blocks? Made of aluminum and the price is right down my alley. |
The lift appears to be a superlift or skyjacker. I can't remember which, but one of them uses tons of springs that longer incrimentally. The lift seems to really come from the stacking of the springs, more so than arch in this case. |
In pictures 3 and 4 what is that short block between the stock leaf block and the add-a-leaf??
| Sponsored Links |
