Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 10-23-2009, 10:34 AM
smboudreaux smboudreaux is offline
Caster correction help
currently i have the 1st gen of rough country 3" w/o the radius drop brackets. alignment in horrible. tracks bad. floats horribly. a couple dif alignment shop told me they cant get enough adjustment out of what i have. heres my question. should i buy the drop brackets from rough country or just get some caster cams from someone like icon? i'm getting new tires in a couple weeks and i want to get this straight before i get the new rubber
Old 10-23-2009, 11:38 AM
DCSpecial DCSpecial is offline
Supporting Vendor
Either drop brackets or the cams will both give you more postive caster which is what you are after.
Old 10-23-2009, 04:32 PM
can i make the assumption you guys sell the icon caster cams?
Old 10-23-2009, 07:05 PM
Supporting Vendor
Yep, these are the cams out of the Icon 2.5":
Icon Vehicle Dynamics 2005-2008 FSD Alignment Cam Kit - Front Suspension Alignment Cams - Truck Toyz Store
Old 10-28-2009, 06:35 AM
Slick02 Slick02 is offline
You really need to check your alignment angles before you start throwing parts at it because you could concievably make it drive worse if they are improperly set-up.
DCSpecial,
have you ever run into steering bind when using the larger eccentric cams to correct alignment angles putting the ball joints in a bind?
Old 10-29-2009, 04:26 AM
Supporting Vendor
A 3" lift without any caster correction will have the caster setting too negative.
I run the Icon caster cams on my essentially stock height 2007 F-350 to run increased positive caster as IMO the stock caster setting is too low.
As for steering bind, we've never had an issue.....and that includes trucks/suspensions that we've setup with much more positve caster than even my truck has.
Old 10-29-2009, 06:55 AM
Just curious, I've run into it a couple of times in the past using the superlift "magic cams"
that are adjustable on some of the stuff with bigger lifts.
Old 10-30-2009, 10:27 AM
Supporting Vendor
The Icon cams are fixed, no adjustment.
Old 10-30-2009, 10:31 AM
Dave Dave is offline
Obama sucks
Dan can you email me installation instructions for the Icon cams
Old 10-30-2009, 10:52 AM
Supporting Vendor
http://www.iconvehicledynamics.com/p...con_6-2530.pdf
