Getting trac bar bolts started...
OK, everyone. This question applies to anyone who has ever removed the two bolts holding the trac bar to the frame. How in the he%# do you get them started back? I installed a leveling kit on my 06 250 today and I have spacers and new bolts for the trac bar, but I could not get the new bolts started in the nut which is located inside the FULLY BOXED frame. There is no way to hold tension on the nut to hold it in place while you start the bolt!!! The nut has a long flange made on it to keep it from spinning inside the frame, but it causes the nut to lay over when you remove the bolt, thus making it almost impossible to get the bolt started. I finally re-installed the old bolt(only took one all the way out) and it took the better part of an hour to get it started in the nut again. I did a search and found nothing related to this, so there must be something I am doing wrong if no one else has ever had the problem when installing a trac bar or the bolts, at least. Someone please tell me the secret!!!
There is an access hole just in front of the coil bucket. Take the nut retainer out and be sure it is not bent and the threads are clean. Be sure the threads on the bolts are clean too and I would coat with anti-sieze or never sieze. Get them hand tight then I would use an impact if you have one to suck the bolts tight. I assume the trac-bar is not bolted to the bracket?
When I installed mine, I just used grade 8 hardware, but it is tricky to back-up the nut. |
Done! Fixed this problem. I drilled a small 5/16" hole adjacent to the bolt on the outside of the frame. This allowed me to take an old welding rod and press the nut down and hold it in place while starting the new bolt with the spacer installed. Upon further inspection, I found that you can get to the right side nut(or rear) since there is an opening on the inside of the frame that allows you to reach the nut with your fingers. Sprayed hole with undercoating real good to prevent rust and good to go. Maybe this will save someone else the possible trouble they may encounter trying to install the trac bar bolts.
What in the world are you talking about? He was just asking how to hold the nut, to get the bolt started lol Last edited by Evil Eye; 09-30-2010 at 10:38 AM. |
