leaf springs - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-11-2009, 09:53 AM Thread Starter
leaf springs
i got the twin i beam front suspension, and the leaf springs are shot, so its sitting with horrible camber, were can i get good leaf springs, for a good price
midnightblue7.3 is offline
post #2 of 7 Old 10-11-2009, 10:10 AM
strokin95style's Avatar
I got the Twin Traction Beam under mine too, and i also have the same problem. I have 2 front leaf spring packs out of a first gen 7.3 that i got from a salvage yard. i plan on cutting the ends off the springs, and putting a little arch in them with a shop press at the shop, and adding them to the existing springs under mine. it will ride like a log truck, but it wont have the negative arch in the springs, it will firm up the ride in the front, and also be the same as a leveling kit. Im hoping that it will raise the front up about 2 inches when i get done.
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
post #3 of 7 Old 10-11-2009, 10:38 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
Atlas spring makes a good solid replacement!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #4 of 7 Old 10-11-2009, 10:46 AM
97Beast's Avatar
Quoted: 13 Post(s)
Oh boy.
I used to have the same negative camber problem on my '97 and I ended up putting on some heavier 3 leaf springs. It was a bad idea, the springs were twisted and I now had positive camber, the twist was hard on the spring bushings.
I ended up swapping them out for some new factory springs, and now everything is fine.
If you want the lift in the front it is imperative that you do things right and buy a kit with a drop-down bracket, like I plan to do.
I'm looking at getting this kit, and the spring packs should give you the height that you'd want, and you will be able set your wheels up straight.
2.5" 1997 Ford F250 Lift Kit - Tuff Country - Top Gun Customz
John
'97-F-250 PSD CCSB 3.55s E40D, Dana 60, PMF 2.25" RSK, U Code SD Springs, 315/75/16 TerraGrapplers, Tow Mirrors, Colibert Tow hooks, RDS Stage 1s, PHP 80hp, RiffRaff 6637, 3"DP, 4" Exhaust, 6" Tip, Power Front Seats, Rear 40/20/40, Explorer OHC and Autolamp Rearview, EATC, Cree LEDs & more
'89-Bronco 5.0l 33"s Free flowing exhaust, 06 SD power seats, & more (SOLD)
'80-M35A2 "Deuce 'n a Half" W/winch Multifuel Soft top
97Beast is offline
post #5 of 7 Old 10-11-2009, 10:53 AM
KeepinItFord's Avatar
I put an Add a leaf in my front when i still had my TTB front end. and after about a month it the spring was bent backwards agian, but not as bad, so when i took the axle and leafs off to do my new front end, the leafs sit perfectly flat when of the truck, when they used to be still arced while up in the air, Idk Why?
Good luck with fixing the front axle camber!
KeepinItFord is offline
post #6 of 7 Old 10-12-2009, 01:40 AM
daddyusmaximus's Avatar
Quoted: 12 Post(s)
Originally Posted by 97Beast View Post
Oh boy.
1. Get a straight axle conversion.
2. Why did you have to put in a photo of the Bronco? I love them, and they don't make 'em any more. Maybe if I win the lotto... and cut 3 feet out of an Excursion...
3. Get a straight axle conversion.
99 F-250 Super Duty, 4X4, CCSB.
AKA: The Liberty Wagon.
daddyusmaximus is offline
post #7 of 7 Old 10-12-2009, 01:56 PM
97Beast's Avatar
Quoted: 13 Post(s)
I'd love to get a straight axle. That will be in the works for the future.
The Bronco, its my other toy and I figured my two Fords made a pretty cool sig pic. I use the same picture in my sig on other forums.
John
97Beast is offline
