Cut out fender flares - Ford Powerstroke Diesel Forum
Old 10-11-2009, 08:27 AM
I have a 2003 f250 with a 10'' lift. I am running a 39.5 tire on the truck.
If I do the cutout fender flares, what size tire do you think I can put on the truck. I am wanting to go back to a 20'' rim.
Here's a pic. of the truck now.
Old 10-11-2009, 08:36 AM
I think you could run 44's but I like the wheels that are on it much more then any 20's. I just never could get in to big rims.
Old 10-11-2009, 08:51 AM
Send a message via MSN to Jesse.James
what is the best tool to cut out the wheel wells with? i was thinkin a plasma cutter?
Old 10-11-2009, 09:13 AM
IMHO I would say a die grinder and a small reciprocating saw unless you are very steady with that Plasma Cutter.
Old 10-11-2009, 08:56 PM
I used a sheet metal nibbler and a jig saw. Yes I used a jig saw. If I could do it over again I would use the nibbler and angle grinder with a few cut off wheels. I'm running a 8" and with the cut outs my 38's look tiny. I would say 44's fore sure. You could prob go
bigger.
Kyle
Old 10-11-2009, 09:05 PM
Thanks guys. I want to go to a 44'' tire.
Old 10-12-2009, 05:49 AM
Lbs Lbs is offline
Sheet metal nibbler and die grinder as stated before. If you like the STS that you have now they make those in a 44" for a 20.
Old 10-13-2009, 02:42 AM
anyone got any pics of the cutting?
Old 10-13-2009, 04:16 PM
try this out
Truckblog - Member Gallery
Old 10-14-2009, 04:16 PM
thanks that is some good info
