Alignment woes... - Ford Powerstroke Diesel Forum
Old 09-25-2009, 05:04 AM
Send a message via AIM to nccatfan
Alignment woes...
Just wondering what you guys are accustomed to paying for an alignment on your Super Duty's. I went to the Ford dealer and they ballparked me @ $250! Is that accurate, or are they jerking me around?
Old 09-25-2009, 06:35 AM
$250 to align it?? That sounds way off base. Were they having to replace parts before the alignment can be done?
Old 09-25-2009, 06:51 AM
i paid 105 for an alignment on mine with 35" tires. I had to go to a specialty shop to get it done, dealer said truck wouldnt fit on their rack.
250 is robbery- shop around.
Old 09-25-2009, 07:28 AM
Thought so. Guy behind the counter went on about it being a 4 hour job and maybe having to do shims and/or camber bushings. I may be naive at times, but I know what an alignment is... I just don't often take my truck to someone else for repairs since I can do it myself (aside from tires and alignments), so I'm not sure how to price things out.
SOB wanted $150 just to check it! "Well, getting it on the rack and set up is half the job."
Old 09-29-2009, 04:17 AM
I own an alignment shop and IF we have to replace both offset camber/caster cams, the alignment runs about 220.00 plus tax, but its not very often that we have to replace both alignment cams and labor wise it takes app 1 to 1.5 hours IF we have to do it complete.
Old 09-29-2009, 04:25 AM
Well I get my truck checked all the the time and if it needs aligned I get it for 49.99
Old 09-29-2009, 08:44 AM
I've been told mieneke is good and cheap. Just figured I'd give my local Ford dealer some business. Didn't think they'd try to con me that bad!
Old 09-29-2009, 09:18 AM
What your getting for 49.99 is called toe and go,,,setting toe-in is a partial alignment.
