06 4x4 dually leveling....lowering rear that is. - Ford Powerstroke Diesel Forum
Old 09-23-2009, 07:15 AM
I'm wanint go to lower the rear of my 06 4x4 shortbed dually so it will sit level with the front.(guessing 2") I don't want to raise the front due to it's hard enough for family members to get in and out.
Question is should I get a pair of drop shackles or remove the 2" block?
With either option will I need to adjust the pinion angle?
If the 2" block is removed will the leaf springs sit correctly on the rear axle and bolt up correctly?(provided I get shorter U-bolts)
One last thing will this throw off the alignment on the front?...i.e. Camber and Toe
Thanks all for the help.
Old 09-23-2009, 07:19 AM
the leafs should sit fine on the axle just set the center bolt in the hole and get some shorter u bolts ......
ohh yeah is it a 250 or 350
Old 09-23-2009, 09:01 AM
Dually = F350
Are shorter shocks needed????
Old 09-23-2009, 11:09 AM
Drop the block and get new rear u-bolts.
