Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 09-13-2009, 11:35 AM
Powerstroke_soldier Powerstroke_soldier is offline
WILD PHIL
Location: Right now in Baghdad, Other wise Killeen Texas
Send a message via Yahoo to Powerstroke_soldier
Crazy shaking and jerking in my suspenion
Im currently deployed and I just had a lift installed on my truck. I went with a 6 inch tough country with dual steering stabilizers. The truck drove fine before now that the lift is on my mechanic is telling me if you hit a bump above 30mph it starts hopping and jerking. Does any one have any idea of what the problem may be? Ive been told I may have some bushings out. Its a 2005 4x4 XL powerstroke with 47k miles on it. I had a front end alignment done on it 10k miles ago with stock suspenion and everything was fine. Any body have any ideas?
Old 09-13-2009, 12:03 PM
Banshee365 Banshee365 is offline
You are experiencing the "death wobble" It's in your steering system, not suspension. It's not so good on the steering parts when this happens. Ford issued a TSB or some sort of bulletin on this and they claim it is mostly due to underinflated tires. Have your's checked. My truck did this with a pro-comp 6" lift and I had to get DR/Icon dual steering stabilizers to get it to go away. Doesn't do it anymore. I think the gas stabilizers are much better than the hydraulic stabilizers because they always are pulling the steering to the center. Unlike a hydraulic stabilizer, the gas ones will no remain where you push/pull the cylinder. They go back to center. Do some searching on "death wobble" because I'm 99% sure that's what your problem is.
-Kelly
Old 09-13-2009, 12:17 PM
WILD PHIL
OK thanks alot kelly. Turns out he hadnt installed the steering stabs yet. So hopefuly thats the suloution.
Old 09-13-2009, 01:24 PM
WILD PHIL
Ok dual stabs are on and the problem is gone. Thanks alot Kelly.
Old 09-14-2009, 12:21 PM
caryt caryt is offline
IMO lifts over 4" need the 4 link arms as you can add extra castor thats really needed on the '05 and up.
Old 09-14-2009, 06:12 PM
DCSpecial DCSpecial is online now
Supporting Vendor
Have you had an alignment done since the lift?
I'd lean towards your caster being a little too negative and/or trac bar/trac bar bracket being loose.
Stabilizers will help minimize feedback from the road.....but the "death wobble" is caused by other issues.
Old 09-15-2009, 08:27 AM
WILD PHIL
sORRY GUYS, he acually installed the dual steering stabs. ONCE THOSE WERE ON IT WAS GOOD. nO PROBEMS SINCE THEN. hOPEFULLY THE WHEELS WILL FIT WITH THE SPACERS.
Old 09-15-2009, 08:33 AM
WILD PHIL
ALso is it better to do the alignment with the 37s or the stock?
Old 09-15-2009, 05:57 PM
Supporting Vendor
As long as the shop can align it with the aftermarket tires and wheels then do it with them on.
