need a track bar measurement 2000 f350 owners HELP!!!!!! - Ford Powerstroke Diesel Forum
Old 08-31-2009, 03:39 AM
Send a message via MSN to Rockstar Edition Send a message via Yahoo to Rockstar Edition
Hey guys so I had my wife measure the trac bar and she measured 39" eye to eye....( I think she measured the drag link ) lol......Im having a custom adjustable trac bar made for my 10" LIFT........and need measurements so it's a hair longer than the 2000 trac bar........someone please post up a measurement, my truck is a 2000 ford f350.......please help, I need this ordered and payed for like TODAY in order to get my lift installed this weekend in Florida.......
Chad
Old 08-31-2009, 05:08 PM
With crossover steering or without crossover steering?
39" definitely isn't the trac bar....and adj. trac bar for a lift using stock lower mount and a drop upper bracket is 29".
Of course that's completely the wrong setup if you are using crossover steering and that measurement is of no use to you.
Old 08-31-2009, 05:18 PM
for like 2 weeks Ill be running WITHOUT crossover, but the only place my truck will be sitting is at the paint shop. is there anyway instead of spending 150 bucks on an adjustable track bar, can I use the stock bar? it measures 30" eye to eye...I have an 8" lift with the 8" kit drop bracket and the stock bar...anyway to use the stock bar?
Old 08-31-2009, 05:22 PM
Cut it, sleeve it, weld it.
For crossover it's completely different upper and lower mounts and a longer bar.
Old 08-31-2009, 05:31 PM
yeah I found an adjustable trac bar for 120 just now and it's the stock length.....and than extended lengths...I can't do it myself as to where Im at..
Im having it done
Old 09-01-2009, 03:20 PM
Lbs Lbs is offline
So stock is 30", and the length needed to go up 2" more is 29"?
Old 09-01-2009, 03:26 PM
29" bars are *adjustable* not fixed.
As I mentioned it's neither here nor there as a 10" lift with crossover steering uses completely different upper and lower mounts that are no longer in the stock locations and a longer adjustable bar.
Old 09-01-2009, 05:31 PM
Lbs Lbs is offline
Sorry, I had misinterpreted what you had said, thanks for clearing it up. Do you know the length of the Icon 05-07 adj. trac bar at it's shortest point? How much adjustment does it have? And lastly will it work for a 10.5" lift?
Old 09-01-2009, 08:02 PM
yeah i bought an adjustable today, pretty excited, it means Ill be getting my lift installed soon..not that I can drive it
Old 09-02-2009, 03:55 PM
I'll see if I can get those specs tomorrow.
Using a 8" trac bar bracket on the 10.5" lift I take it?
