Clearing 40s ? ? ? - Ford Powerstroke Diesel Forum
Old 08-30-2009, 01:05 PM
Clearing 40s ? ? ?
im running a rough country 6" spring in the front and a 4" block in the back (weird i know but thats what the kit came with) with 37/13.50/18 i want to run 40/15.50/22 ... can i just get 3" hangers for the front and 6" leafs in the back to make its 9" in the front and 10" in the back and clear 40s? or will i need more than 9" of lift to clear 40s???...needing help im new at this and im trying to take the less $$$ route thanks..
here is a pic of the truck now
Old 08-30-2009, 02:34 PM
It should in theory fit. I dont know about rubbing though. Good looking truck.
Welcome to the ORG!
Old 08-30-2009, 02:51 PM
I thought that when you exceed 6" lifts you have to worry about brake lines, drive shafts, etc... I could be wrong though
Old 08-30-2009, 02:59 PM
Well you do but I was thinking he was just asking about the actual lift!
Old 08-30-2009, 03:00 PM
Oh i see. clearing 40's would be so awesome. welcome to the org by the way man
Old 08-30-2009, 05:24 PM
thanks guys...and yea i knew about the drive shafts/ brake lines just curious about the lift .....and also about the leveling of the truck do most lifts come like 6-4 or 10-8 how should i go about that if i can clear 40s with only 9 inches up front?? thanks for all the help
Old 08-30-2009, 05:55 PM
Depends on the look your goin for. My last truck had 11"s total. 6" springs and 5" hangers in the front with 10" spring and factory F250 block in the rear. It sat a lil over the 39.5 TSL's. 8" and 38's is a common set up so with 9" you should be good but will prob be a lil tighter than I like.
Old 08-30-2009, 06:45 PM
what is the ideal lift size 2 be alright with 40s?
Old 08-30-2009, 06:53 PM
Well I run 8 in the front and 4 in the back and 37 but I have had 38's on here with no rubbing. I dont see why 10 in the front and leveled off in the rear wouldn't be enough!
Old 08-30-2009, 08:02 PM
Send a message via MSN to Rockstar Edition Send a message via Yahoo to Rockstar Edition
in order to clear 40's WITHOUT rubbing you'll need 10" of lift...you won't need new brake lines, just get extension brackets( IVE RUN 11 WITHOUT LINES ) and you'll need your front driveshaft extended.
Chad
