Fabtech radius arm drop 05f250 - Ford Powerstroke Diesel Forum
post #1 of 1 Old 08-20-2009, 06:42 PM Thread Starter
bondsman's Avatar
Just wondering if anyone out there has the Fabtech Radius arm drop brackets for the 8" kit and what is the drop from the OEM bolt to the bolt on the drop bracket to the radius arms.
Reason I am asking is I have a 4" lift with radius arm drop brackets and I came across the following for a steal and want to gather the remaining parts and install it:
2 - 8" Fabtech front coil springs
1 - Fabtech Trackbar drop bracket
1 - Drop pitman arm
2 - Fabtech traction bars with new joints and all mounting hardware.
I looked up the basic kit and I think I need the radius arm drop brackets (might be able to use mine if they are the same drop), sway bar drop brackets (I can fab my own if someone can give me the dimensions, or if they are cheap enough, I will buy a set), some brake line relocation brackets, and some 7" rear leaf springs and shocks. Oh yeah, I picked up my half a lift kit plus traction bars for $350.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
