jacked rear end lift - Ford Powerstroke Diesel Forum
Old 08-15-2009, 10:17 PM
new to the ford world and love my 03 sd. just have a question.... the guy i bought the truck off of had the truck lifted and it has 2 four inch blocks(each side, not including the factory block) in the rear end to lift it.... the blocks have shifted and i have never seen 2 lift blocks used. the rear end has slightly shifted and is eating up tires.... what would be the best way to fix it? i thought about doing an ad a leaf and a bigger factory block and a 5 inch block. what are your thoughts
Old 08-15-2009, 10:29 PM
maybe take it to a spring shop and have your back springs re-arched and toss the blocks.if not you could try finding different blocks
Old 08-15-2009, 11:50 PM
buy some new lift springs, and a set of traction bars
Old 08-16-2009, 03:16 AM
Send a message via MSN to Rockstar Edition Send a message via Yahoo to Rockstar Edition
use lift springs....or keep your ride perfect and use the ouo traction blocks( they'll make the lift size block whatever you want ) and it has your traction bars....they're just really expensive.....
Old 08-16-2009, 08:43 AM
yeah been looking into traction bars but not sure what ones are the best to getbut no real expensive.
Old 08-16-2009, 09:15 AM
I didn't like my setup when I bought it either and it was just the factory blocks with 6" blocks stacked on top of those. I did the math and completely eliminated my blocks all together. Just put some 8" Springs on there and called it a day. It did ride a little rougher, but I don't get wheel hop in the sand anymore and I feel a whole lot safer for $525.
-Aaron
Old 08-16-2009, 09:27 AM
stacked blocks are a nono either get one huge block or grab some lift springs with your stock block
Old 08-16-2009, 07:07 PM
i think ill prob just get rid of the blocks and get some lift springs for now. love the way it rides right now but untill i can get some tracktion bars at least the tire wont get any worse........
