Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
  #11 (permalink)
Old 07-06-2009, 10:31 PM
dpbuckster dpbuckster is offline
99+ F350 were suppose to have D60's
02+ F250 should be D60's
Excursions all had D50's
Now keep in mind 05+ went to coil sprung setups.
I'd look for 05+ axles, D60 and Sterling 10.5. You should be able to find a low mileage set that's ready for gears/lockers for $1500. Stick with coils and do a simple 4 link or radius arm setup up front with trac bar. Coilovers if you have the cash.
  #12 (permalink)
Old 07-07-2009, 12:26 AM
Klitch Klitch is offline
only thing about the 05+ coil setups im not keen on is im not the most brilliant when it comes down to figuring out suspension geometry, but i feel confident on the leaf sprung up front as far as figuring it out goes. granted, im sure ride quality will be significantly better on coils than leafs.
05+ also have larger calipers? will 17" wheels clear?
