Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 07-02-2009, 08:38 AM
coope3 coope3 is offline
Traction bar pics I made
Here are a couple of pics of some traction bars I built for buddies.
Old 07-02-2009, 08:43 AM
cowboyf250 cowboyf250 is offline
dam nice!!!
Old 07-02-2009, 08:54 AM
HarleyF250Guy HarleyF250Guy is offline
I would be interested in a set..........that is if your willing to make more!
Old 07-02-2009, 09:02 AM
me to. i get nasty axle hop in the sand
Old 07-02-2009, 09:27 AM
TANK'S 250 TANK'S 250 is offline
Looks good,...but the front brackets are going to need to be bigger,...over time...the front mounting bolts are going to "wallow" out the frame....trust me.
That is a ton of leverage and torque on that little 3" wide front bracket....
Old 07-02-2009, 09:44 AM
boschert_72 boschert_72 is offline
Trac bar??? um no. Ladder bars? Traction bars? axle rap control bars?
To my knowledge the trac bar is in the front.......
Just ringing yur bell buddy, those look great!!
How much for a set of my own???
Old 07-06-2009, 02:50 PM
panheadjay panheadjay is online now
here is something i learned along time ago drag racing with my buddys. if you have ladder bars you need a floater setup on the axle so the axle can move back and forth when the springs travel up and down. now coil springs are exempt, because the springs move back and forth. in your case should'nt be a problem because you dont have a top mount on the rear end. i had an f 250 with ladders i made no floater, broke the heim joints, built a blazer, made a floater with ladders work great. reason for that, adjustable rear end. you can put more or less wieght on the rear for traction. boschert 72 is right on the metal thickness, build it twice as stronge as you think it should be. i have found that to be true on my harleys and there puny little motorcycles. sorry for being so long, just thought i'd share if it even matters to you. keep up the good work before you no it you wil be selling faster than you can make em.
Old 07-06-2009, 02:55 PM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
Those look great dude!
Old 07-06-2009, 09:16 PM
PowderStroke PowderStroke is offline
looks unreal man!
