Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 07-01-2009, 12:48 PM
cam31 cam31 is offline
Drop pitman arm questions
I just installed a 4" Superlift on my 05 F250, but it didnt come with a drop pitman arm. How necessary is this piece? It seems like it would be a good idea to get one ordered. Im also going to get the carrier bearing drop kit as well. To me, I think these pieces should have with the kit. I guess there is a reason its priced as cheap as it is.
Any other suggestions to complete this kit?
Old 07-01-2009, 12:53 PM
boots16 boots16 is offline
i had to get one for my '02 cause it would'nt aline just right. and the steering wheel they could'nt get straight.
Old 07-01-2009, 12:55 PM
NotStock NotStock is offline
What year truck? To save yourself some money, just go buy some flat washers for the carrier bearing drop. All the kits use is a peice of flat stock with 2 holes drilled in it....
Old 07-01-2009, 01:00 PM
Rob Rob is offline
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
the drop pitman arm will keep the steering linkage at a decent angle so as to not wear out your tie rods.. do it and save yourself a headache later.
Old 07-01-2009, 01:50 PM
TxFireman1972 TxFireman1972 is offline
I know my DR/ICON 4.5" kit does does not require a Dropped Pitman Arm. They dont use a different pitman arm until you go up to their 7" kit. I would say if you need ut they would have included it with the kit.
Old 07-01-2009, 01:53 PM
TANK'S 250 TANK'S 250 is offline
The reason it didn't come with the kit is because it isn't needed on 05+ trucks with only a 4.5" and smaller lift.
all you need is a shim kit, and an adjustable track bar if your's didn't come with one.
let me know if I can help.
