Go Back   Ford Powerstroke Diesel Forum > General Topics > Suspension & Steering
Old 07-01-2009, 08:18 AM
ottr1967 ottr1967 is offline
Question Front Leaf Spring Advice
I have an '03 F250 fx4 with the 6.0L. My driver's side front spring has sagged over an inch more than the right side. I occaisonally bottom out the driver's side, and I have a noticable squeak from this side also.
Looking at my spring code on the door panel, I have code UP. I looked in the maintenance section of the forum and it indicates that my front springs are the 4800 lb set, I am not sure about the rear.
Any advice on whether I should replace with the stock springs, upgrade to a higher rate stock spring, or go with an aftermarket set?
Any help is appreciated.
Old 07-01-2009, 11:30 AM
caryt caryt is offline
Get a set of V codes 5200lbs for the front, the ones you have are to soft IMO and thats why you saged.If you want to get it closer to being level get X codes..6k lbs. If you go to X codes you will need a adj track bar to recenter the axle.
Cary
