Recon cab lights - Ford Powerstroke Diesel Forum
Stealth Automotive Stealth Automotive
post #1 of 7 Old 11-16-2008, 09:55 AM Thread Starter
Recon cab lights
Will those recon 99-08 work with my 95psd, like match the contour of my roof? Does the kit come with all the wiring?
1995 F250 7.3 turbo
3 inch dp into 4 inch exhaust
tymar intake, Isspro boost, pyro, tranny temp gauges
tow and go shift kit, DIY electric fuel pump system with fuel pressure gauge,bronco tank mod
kcm ss hpx line, stancor gpr, 203 thermostat, 03 starter
TWchip 6 postion daily,econo,tow,street,xtreme,highidle
Banks intercooler and pipe kit,Idm Mod,CCV Mod
Plant drive wvo kit(hotfox,vegmax filters,26fphe, vegthermmega and gauges for cooliant and wvo temp)
Dana 60 front axle swap
7.3TurboDiesel is offline
post #2 of 7 Old 11-16-2008, 10:02 AM
Raul@Stealth Automotive's Avatar
they come with everything.. and i have no idea if they will fit a OBS truck... i have not had anyone try them on a OBS truck yet...if your going to buy make sure you buy the LED new install kit.. if you buy just the lenses it will not come with the base or wire harness...
-Raul
Raul@Stealth Automotive is offline
post #3 of 7 Old 11-29-2008, 08:11 AM
big25country's Avatar
Send a message via Yahoo to big25country
Here's a cab light question. I have a 2002 Lariat/LE that comes with a visor with cab lights in it. I've looked all over for a replacement but can't find one. I would really like smoked lens to go in it, but can't find them. Just going to see if maybe you knew of any.
Thanks
White 02 F-250 Lariat 7.3, 4dr, 4wd, Auto.
DIY 6637 intake, Foil Delete, 2" lift, Cobra 29 CB w/ 102" whip, Harley Headlights, 305/70 R 16 NITTO Terra Grapplers,
4" Grand Rock exhasut w/ 5" Aussie Stacks, TW 6 pos chip, Autometer gauges
big25country is offline
post #4 of 7 Old 11-29-2008, 10:02 AM
Thanks
i have no idea if anyone makes a smoked lense for the visor lights... if you get OEM ones you can just smoke them
-Raul
post #5 of 7 Old 11-29-2008, 10:07 AM
Chug-a-lug!!!
colberjs's Avatar
Quoted: 11 Post(s)
I put those lights on my '06 PSD and I dont remember the light base itself having any contour. I think that as long as you put silicone on the bootom of it before you bolt it to the roof like suggested, then you will probably be fine.
P.S. I won't be responsible if for some reason it doesn't work!! LOL
Jesse
2011 F-250 Fx4 CrewCab Short Bed
Bone Stock............Or Is It?
colberjs is offline
post #6 of 7 Old 11-29-2008, 10:09 AM
-Raul
I can smoke my current Amber ones? That's cool.
post #7 of 7 Old 11-29-2008, 10:11 AM
pull them off and use some tint spray....
