RECON Clearance Light Install - Ford Powerstroke Diesel Forum
Stealth Automotive Stealth Automotive
post #1 of 36 Old 07-28-2008, 06:21 PM Thread Starter
stroken04's Avatar
First of all, I want to thank Raul for the awesome deal on these lights. He is a great vendor. I would recommend him to anyone,so if your thinking of buying anything you should check out Stealth-Automotive. (fyi Raul did not pay me to say that )
I finally got my lights installed Saturday, it was much easier than I expected. I was a little nervous drilling the first hole in the cab of my truck, but after that it was smooth sailing.
The only thing I didnt like about the kit was the screws that were supplied. I went to the hardware store and bought some stainless steel nuts and bolts to replace the screws.
The first thing I did was cover my dash
Then I took both of the plastic pillar covers off, The drivers side was a PITA because of my quadzilla was in the way.
then I took the sun visors off
Taking the overhead console off was a little nerve racking, since it sounds like it is about to break into 100 pieces, but it came right down
I don't have any pics of me drilling the holes, but I taped everything off, and measured everything about 8 times before I did any drilling. I highly recommend a good set of drill bits for this job
I decided not to buy the ford wiring harness that is needed to finish the install. I found the parking light wire and used a wire tap to access the power
After that I soldered a 300 ohm resister between the lights and the power source and covered it with clear heat shrink tubing
Here is the final results
I dont think they are as bright as they should be, so im going to buy a different resistor and try that out. I will update the thread when i install the new resistor
If anyone has any questions on installing clearance lights just let me know
stroken04 is offline
post #2 of 36 Old 07-28-2008, 06:22 PM
IUStroker6.0's Avatar
looks real good man... those flames are baddd too
2004 F-350 Reg Cab Long Bed 6.0l: Sold
2007 Dodge 2500 5.9l Cummins
White Quad Cab Short Bed 4x4
All stock
IUStroker6.0 is offline
post #3 of 36 Old 07-28-2008, 06:26 PM
powerstrokin
drz400smoto's Avatar
Quoted: 22 Post(s)
Send a message via AIM to drz400smoto
looks good, I would like to install some eventually
--DREW
2001 F350 386 HP/ 754 Torque -- SOLD
2012 F150 Ecoboost -- SOLD
2016 F350 6.7 -- Bone Stock
CSP
drz400smoto is offline
post #4 of 36 Old 07-28-2008, 06:26 PM
f250ghost's Avatar
Are those LED?
-Ben
2011 F250 FX4
6.7 PowerStroke
f250ghost is offline
post #5 of 36 Old 07-28-2008, 06:27 PM Thread Starter
stroken04's Avatar
Thanks guys!
and yes they are LED's
post #6 of 36 Old 07-28-2008, 06:39 PM
Raging Lunatic
choctaw's Avatar
Very nice
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
post #7 of 36 Old 07-28-2008, 06:52 PM
Strőkër~X's Avatar
nice work Wes....you could not pay me to drill in my cab roof!!!
im still alive and kickin...find me on FB..."StrokerX1"
SOLD my truck, another Diesel within 2011
NOTE: if your on OK and need some PSD work done, i know a dealer tech who does the work....PM me!
Strőkër~X is offline
post #8 of 36 Old 07-28-2008, 06:53 PM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Looks good, Wes! I like them a lot.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 36 Old 07-28-2008, 06:58 PM Thread Starter
stroken04's Avatar
oh come on, why would you not want to drill holes in the top of a 45K truck
post #10 of 36 Old 07-28-2008, 07:12 PM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Man, I wish it was still worth 45k...
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
