Details
Some 2008-2010 6.4L Powestroke trucks come equipped with a Tire Pressure Monitoring System (TPMS). This system has a wireless transmitter mounted inside each tire that senses pressure. This pressure measurement is monitored by a computer in the cab and will cause fault lights to illuminate if the tire pressure gets out of a calibrated range, or a problem exists with one of the sensors. This becomes a problem when non OEM tire and wheel combinations cannot support the required factory pressure calibrations of the TPMS system. Or for those wanting to run two different sets of tires/wheels during different driving conditions.
H&S Performance once again pioneers the industry by releasing a tool to allow the end user to adjust the TPMS parameters. This has never been done by an aftermarket company before. With the H&S TPMS module you have full control over the system, allowing you to change pressure thresholds or completely shut the system off.
This module will plug in-line with your existing H&S tuning device ONLY during TPMS adjustment. Once TPMS adjustment is complete, it can be removed. Your H&S device will need to have TPMS compatible software installed. Make sure your H&S product is up to date by vising the H&S downloads section. Once updated correctly you will see a "TPMS adjustment" option in the main menu options. Use the onscreen instructions to walk you through the programming process.
Applications
* Fits 2008-2010 Ford 6.4L Powerstroke
Features
* Enables adjustment / disablement of the TPMS (Tire Pressure Monitoring System)
* Front and Rear pressure independently adjustable from 0-100psi
* Must be used in conjunction with an H&S Black Maxx, Mini Maxx, or XRT Pro
You can purchase it here: 2008-2010 Ford 6.4L Powerstoke TPMS Module
