6.7L EGT Monitoring
EGT Monitoring Details:
The parameter used on the Phalanx to monitor EGT is found under Ford UDS Drivers, labeled as "Spartan EGT Using EGR Input".
You'll need an EGR Blocker/EGT kit from a reputable vendor such as Street Diesel Performance, River City Diesel, etc. With this kit installed, please ensure that you are using one of the 4 exhaust temperature sensors, removed from your exhaust, installed into the blocker plate and plugged into the wiring harness connector where the old EGR cooler outlet temperature sensor was removed.
The instructions supplied with the EGR Blocker/EGT kit from your vendor should provide ample instructions for this. However, we will be releasing our own instructions set available for download on our site over the weekend.
