Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > Sled Pulling
Sled Pulling How-to, FAQs
Old 08-07-2008, 08:15 AM
Marty Marty is offline
International Threat
My pulls @ the buck
YouTube - Sled Pulls at the buck
And here is a video I found on youtube while searching for my name
YouTube - Maintain's first dyno run
Old 08-07-2008, 08:23 AM
AWD Bare AWD Bare is offline
Schweeet....
Old 08-07-2008, 08:24 AM
willholl79 willholl79 is offline
What broke when you came unhooked?
Cool vids.
Old 08-07-2008, 08:25 AM
Dave Dave is offline
Obama sucks
What happened on your first hook in the vid?
Old 08-07-2008, 08:41 AM
farmboypowerstroke farmboypowerstroke is offline
sounds like you up shifted? If you didn't i bet you would have went farther. nice pulls there. Did you drag race?
Old 08-07-2008, 08:45 AM
ABOBB ABOBB is offline
Is it even worth it???
Broken hitch on first pull.... Seen that happen before.
The Decision Maker is a whole lot harder to move than it looks like, isn't it Marty??
Old 08-07-2008, 08:50 AM
mudrunninpig mudrunninpig is offline
D80 Axle Snapper
Nice pulls
Old 08-07-2008, 09:03 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
go marty , go marty , go
Old 08-07-2008, 09:11 AM
I broke the 2" steel stock that I welded to. Probably heat transfer weakened it.
Now, for the discussion... I want to be in 3rd. I could hold 2800, 3200 or anywhere in between in 2nd gear and 3rd gear no problem. I've talked to jody and I think I'm going to adjust two of the tunes. One is going to be locked in 2nd from the start for hard tight tracks (like the buck usually is) and the other is going to be locked 3rd from the start for slick tracks like the buck was that night since I was the first puller and it had rained just a few hours prior.
Old 08-07-2008, 09:13 AM
redstroker_2002 redstroker_2002 is offline
KVFD
what were your egt's?
