Excursion Drivesahft - Ford Powerstroke Diesel Forum
Sled Pulling How-to, FAQs
post #1 of 1 Old 10-02-2013, 01:45 PM Thread Starter
I got a 2000 Excursion with a 7.3. The truck is lifted 6" on 35". I have 3.73 gears in the truck. I was wondering what kind of driveshaft you guys recommend for such a setup. It currently has a single driveshaft design with 1410 joints. I am getting some vibration at 55 and up. I also occasionally truck pull the truck.
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
