First Pull tonight! - Ford Powerstroke Diesel Forum
Sled Pulling How-to, FAQs
post #1 of 14 Old 07-26-2013, 07:37 AM Thread Starter
paintballbryce's Avatar
First Pull tonight!
Despite the butterflys, I'm excited to get my first ever pull in tonight. I'll post up with my results, and what I break
Any advice is appreciated, I know to lock hubs, I'm strapping my front end down, turning the wheel slitghtly left and right, and to start off slow, and then hammer it down. 3rd gear, 4lo. Anything else that could help me out?
Thanks guys, and ill post back shortly!
2006 F250 Bulletproofed - SOLD
2008 F350 King Ranch
Stock for now
paintballbryce is offline
post #2 of 14 Old 07-26-2013, 07:39 AM
6.0newb!'s Avatar
Quoted: 17 Post(s)
Good luck, can't wait to hear about it! Think you pretty much covered it though
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #3 of 14 Old 07-26-2013, 07:44 AM
JD3020's Avatar
Keep the wheels straight, no reason to saw at the wheel, not gonna help ya any. If you feel the truck start to bounce or hop, let off the throttle. If something doesn't sound or feel right, let off the throttle. Just remember to NEVER touch your brakes, unless you feel like getting some new dents.
My first time hooking i was nervous as heck, probably the most nervous i've ever been, because i was so worried about destroying the truck. Took it slow and steady down the track, and didn't do too bad, but far from good. 2nd hook i wasn't as worried, and let her eat. This week i've got 2-3 hooks planned, so i'm starting to get more comfortable with it. But after your first time, your hooked(pun intended) for life! I'm already planning several thousands of dollars of upgrades just to get my truck half-competitive.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #4 of 14 Old 07-26-2013, 07:49 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
I would recommend airing down a bit in the front. I always pulled better with about 10psi lower in the front than the back, i usually ran like 50/40 depending on the track. If it doesn't bounce i wouldn't start off slow, the quicker/faster you get that slurred moving the more momentum you'll have to help carry you further.
I haven't pulled with my 08 yet but have been reading about those who did and ive gathered I'm going to use tow haul and 3rd gear, of coarse 4low. I'm waiting to pull till i get wrap bars and front 4link.
Good luck.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #5 of 14 Old 07-26-2013, 07:52 AM Thread Starter
Good luck.
Okay, I forgot about the tire pressure, I was told going slow for the first second or two helps build the turbo up, then you put it to the floor after the sled is moving, but your plan sounds better!
Thanks for the luck, going to need it! Im excited!
Stock for now
post #6 of 14 Old 07-26-2013, 08:05 AM
Quoted: 4 Post(s)
That's why you see pullers sit there for a few seconds before they pull, they're spooling up so they can take off with more power and get things rolling. Before you go try a couple of 4lo launches in the dirt so you can know how much throttle you're brakes will hold, hold you're brakes and throttle till you start building boost, release brakes and hang on.
Brett
post #7 of 14 Old 07-26-2013, 08:36 AM Thread Starter
Awesome, ill give that a shot!
Thanks!
Stock for now
post #8 of 14 Old 07-26-2013, 08:43 AM
JD3020's Avatar
A big reason pullers build boost at the line is because the turbo's are so big, and they're running higher gears. If you tried to just roll out with a large 2.6 or 3.0 turbo and don't have all your ducks in a row, it won't spool and you'll just sit there.
I creep out for a foot or so then start to roll into WOT, that helps to get the chassis and everything loaded and isn't shocking the driveline. Its easier on parts, easier on the truck, should help to prevent bouncing, but it might cost ya a few feet.
There's no real right way to do it, just gotta figure out what works the best for your truck and the track.
Jimmy
JD3020 is offline
post #9 of 14 Old 07-26-2013, 01:10 PM
Quoted: 4 Post(s)
X2
In my 97 7.3 with the h2e turbo kit i couldn't do a foot brake type spool up, it wouldn't build any boost without adding enough throttle to start pushing thru the brakes. I had to go to neutral and rev it up hard to get it to build any kind boost. Then when i put it back in gear and took off there was just enough lag for the suspension to load up and hook before it lit and took off, pushed it into 2nd and let er eat pushing that throttle thru the floor. There's not a better legal rush than that feeling right there.
Brett
post #10 of 14 Old 07-26-2013, 01:40 PM
where you pulling tonight?
zillafreak is offline
