What tune to pull with - Ford Powerstroke Diesel Forum
Sled Pulling How-to, FAQs
post #1 of 10 Old 04-25-2013, 04:56 PM Thread Starter
powerstrokecrzy's Avatar
Quoted: 250 Post(s)
Just as it says, local pull coming up here soon and I'm thinking about it. I run looney wild track as dd but would imagine that's gonna be way to hot. I also have her tow tune not re written for studs or my 175/stock injectors. These are my only two options besides stock. What yall think, or usually do for those with experience?
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #2 of 10 Old 04-25-2013, 05:49 PM
Njstroker91's Avatar
Subbed interested what everyone has to say I'm also looking to pull my truck this year.
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #3 of 10 Old 04-26-2013, 03:30 PM Thread Starter
Quoted: 250 Post(s)
No one has any input?
Sent from my DROID X2 using AutoGuide.Com Free App
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #4 of 10 Old 04-26-2013, 03:31 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 953 Post(s)
Feedback Score: 6 reviews
From what I have been told in the past by guys that pull every year is to put it on the hottest tunes and hammer down.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #5 of 10 Old 04-26-2013, 03:35 PM
gotta_gofast's Avatar
Quoted: 61 Post(s)
Might be something to discuss with your tuner. I sure wouldn't load a drag race tune and run WFO. But that's because I depend on my truck every day. If it were... say... my "toy" and I didn't need it every day then I might be a little more aggressive. Pulling is hard on trucks and adding a hot tune is only harder.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #6 of 10 Old 04-26-2013, 03:40 PM Thread Starter
Quoted: 250 Post(s)
I realize the risk and certainly don't want to break anything, or anything major anyway, a u joint I can deal with. I'm thinking having a mild tune written might do me good. Get some good results without breaking the truck
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #7 of 10 Old 04-26-2013, 03:56 PM
I definatly wouldn't pull without track bars. And make sure your in 4 lo. Talk to your tuner, they can tweak your tune for sledding.
Moto2four is offline
post #8 of 10 Old 04-26-2013, 04:06 PM
RIP Cam!
Quoted: 953 Post(s)
Another thing to consider since you have coil overs in the front is to get some buddies on the front of the truck to sink it down a bit and ratchet strap the coils down some to help with wheel hop.
I will say this.... I have not pulled yet, but several of my friends from the truck club do A LOT and these are all things they have talked about and or done in the past.
post #9 of 10 Old 04-26-2013, 05:41 PM
Full fuel tune wtfo lmao I wanna build a set of ladder bars for sure I get some wrap just stomping it on the road I'm also a stick so I'm thinking 4lo third gear dunno??
post #10 of 10 Old 07-27-2013, 06:03 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
I.well tell you all this.....on the street with hot tunes, i can get egts up there in the 1500+ range no problem..but on the track, not spraying water, my egts never got over 1600....when you put the truck under extreme loads the engine works much more efficiently and it flows better abd the egts don't skyrocket like in the street. Before I had Tony build me a sled pull tune, I used his extreme tune. So my advice is use a hot tune, and let her eat....oh and DON'T look at the egt gauge....ots not hot enough for long enough to hurt something...you might flip out if you look at it..haha
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
