Sled Pulling ???s - Ford Powerstroke Diesel Forum
Sled Pulling How-to, FAQs
Old 07-25-2012, 12:34 AM
Sled Pulling ???s
Truck is in signature. Going to add some arb air locker F/R, Traction Bars, 190s with a stage 3 or 4 MTW turbo. Billet trans and driveshaft probably++
Never pulled a sled, just want to build this truck into something that can pull.
Old 07-25-2012, 12:03 PM
head studs....
I would put it closer to stockish hight also 35s +-.
Jim
Old 07-25-2012, 01:13 PM
You would want to lose the lift and get some smaller tires.
Old 07-25-2012, 04:41 PM
I've seen larger trucks pull sleds just fine?
Old 07-27-2012, 11:40 AM
depends on your suspension set up most of the lifted trucks ive seen hooked to a sled hopped and bucked their way down the track.... even with traction bars.
there is a reason most pullers are running stockish ride height.
Jim
Old 07-27-2012, 06:54 PM
You want a very stiff suspension, much give or bounce and things will get hopping, and then they will break.
Old 07-27-2012, 07:16 PM
Running 8" Icon springs in front and rear and they are stiff. Anyone know how large Denny Hao's truck sits? He pulls the **** out of that sled and he's lifted.
Old 08-04-2012, 06:56 PM
get some bump stops on the truck and that'll help if it'll hop
