need some help - Ford Powerstroke Diesel Forum
Sled Pulling How-to, FAQs
Old 11-03-2010, 05:14 PM
need some help
hi ya'll
This isnt about a powerstroke but im hoping someone on this site can help me out. Im a student at Penn State and im part of the Penn State Pullers. its a 1/4 scale tractor pulling club run the ASABE. Anyways we are redoing the exhaust on our tractor and i need to know if a part exists. Let me explain my dilemma. We use 3 16hp V-Twin B&S engines. One is mounted like all of ours with the crank going lengthwise along the tractor. the other 2 are mounted on the side of that one about 6 inches below and rotated 90 Degrees so the cranks are parallel with the axel. We want to do away with our exhaust now which is a 6 stack configuration the engines on the outside are fine. but i have a problem with the center motor because it will torque on a different axis. i dont think our tubing could handle that. the exhaust will be 1" untill it merges to a 2" lake pipe. all the work will be custom done by us. I want to know if there is 1" exhaust flex tubing or something like it? does anyone know? if you need me to explain more just let me know. Thanks
Old 11-04-2010, 08:50 AM
bump. and no our tractor doesnt look like the one in my sig nor does it spit fire
Old 11-08-2010, 12:06 PM
mid afternoon bump
Old 11-09-2010, 07:09 AM
I would guess talk to you local muffler shop and see what he can get for ya....
Old 11-16-2010, 06:18 PM
here's a pic
Old 11-17-2010, 05:01 AM
pic not loading....
Old 02-21-2011, 07:05 PM
You could go to Home Depot or Lowes and get some natural gas flex pipe and see if you can make that work for your setup
Old 02-21-2011, 07:31 PM
where were you weeks ago Its all good now. we made stacks for it with flappers
hope this works
Old 02-21-2011, 08:08 PM
Brand new to the forum, didn't see anything that said it had been resolved
Old 02-21-2011, 08:31 PM
all good. ill keep it in mind incase i ever run into the problem again and i never did update this
