| Sled Pulling How-to, FAQs |
Midsouth Fair truck pull Sept. 25th
There will be a Truck pull Sept 25th at the MIdsouth Fair In Southaven, MS there will be a Gas Class and Diesel Classes, Hope to see some of you guys there
Here is the address and the rules for the pull Midsouth Fair Truck Pull- Saturday September 24, 2010 Desoto Civic Center 4560 Venture Drive Southaven, MS 38671 · Registration starts at 5p.m. Pulls start at 7 p.m. · 75% payback and a $30 entry fee Truck Pull Classes Gas Class- Street legal gas truck. Anything goes but must be street legal. Stock Diesel Class- Stock Turbo, Aftermarket Intake, Exhaust and Programming allowed, no visible performance modifications other than intake and exhaust. No traction bars, front weight racks. Maximum Weight 8500 lbs Diesel Class 2- Stock turbo, Fuel system modifications allowed, Max weight 8500 lbs Diesel Class 3- Aftermarket Turbos, hanging weights allowed, Max weight 8500lbs Diesel Class 4- Anything goes, nitrous, propane, water methanol, no weight limit Rules ·First Puller in each class gets the option to re-pull ·1” Suspension travel in all classes except Diesel 4 ·If you are unable to drive the truck off the track you are disqualified ·If you have not reached 75ft. you may back up and start over one time. ·All tires must be DOT legal uncut. Except Class 4 ·Exhaust must exit behind the cab in all classes except Diesel 4 ·Nitrous, Propane, Water-methanol allowed only in Diesel class 4 ·If a truck is over 8500 lbs. in the stock diesel class the tech staff has the option to let them pull if no weight has been added. Don’t show up with a full tank of diesel and be over 8500 and expect to pull If you have a Antique or Farm tractor we will be allowing tractors to pull before the truck pull starts, just call to find out how early to show up with your tractor it depends on how many tractors are coming. For questions about classes or rules call Justin Hoback 901-299-4682 |
bump for the night
Allow drop in turbo's (factory pedistal remains) and drop the 1" travel rule and you'll get more pullers.
well ill say something to justin and coltin about it
Tell him he out pulls me when he don't puss foot it, so no complaining about it.
The rules put me in a higher class than his truck lol. |
bump for the day
ttt bump for the night come on guys
