Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > Sled Pulling
Sled Pulling How-to, FAQs
Old 04-30-2007, 12:46 PM
quick26 quick26 is offline
pullin
does anyone blodk up the rear end whe they pull their 6.0?
what gear do you pull in also?
how do you leave with is? on the mat or ease into it then mat it?
Old 04-30-2007, 07:20 PM
mech2161 mech2161 is offline
Blocking the rear is a must. Different assoc. have different rules. Some are solid, some 1" some 2". I take it is an auto? Ease off the line to get it rolling and keep laying the shoe to it. Don't let it go to drive, the gearing is too high.
Old 05-01-2007, 06:13 AM
it is an auto. we can block ours solid, my buddies pull their duramax diesels. we cant hang any weight though, and we are suppose to be 8k max. are you manually shifting the tranny, or put it in a gear and let it shift itself?
Old 05-01-2007, 06:19 AM
Dave Dave is offline
Obama sucks
What do you mean by blocking the rear?
Old 05-01-2007, 06:30 AM
putting a block in place of the bump stop it so that you have no rear end squat
Old 05-01-2007, 06:33 AM
Obama sucks
Oh ok i see
Old 05-01-2007, 10:03 AM
My truck is a 6spd. I hear stories both ways. Only way to see what works best for you is to try it. Look around at the pulls and don't be afraid to ask.
Old 05-01-2007, 10:07 AM
not many strokes sucessfully pullin around here. the only one that competes with the cummins and duramax is a long bed reg cab and he is blocked and spraying and is suppose to have more done to it
Old 05-01-2007, 10:09 AM
Yeh I know what you mean. I would try first to let it shift by itself.
Old 05-01-2007, 10:33 AM
i have been talkin with pat about upgrading my programer to the sct. one of the guys that drives one of the duramaxs rides the van to work with me, and the other i know fairly well. they are both trying to help me go in the right direction. one use to install lifts and brought a set of bump stop relocator brackets by but the would not fit. they dont have much done to the d max other than some huge programers. one has a fuel pump and suncoast tranny, the other just did shim up his fuel rack. both are solid in the rear. they have tried to find out what the other powerstoke has but he is hush hush
