Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > Sled Pulling
Sled Pulling How-to, FAQs
Old 03-14-2007, 08:42 PM
stroknurhrtbeat stroknurhrtbeat is offline
How Do You Pull????
I was wondering how every runs their truck in a sled pull?
4x4high drive
4x4high 2nd
4x4low drive
or any other combo i am interested in pulling and want to know what works the best for everyone. . .i have a 4inch lift and 35inch baja claws if it really makes a difference too any input is appreciated. . . .???
Old 03-14-2007, 08:58 PM
lukecline
Tournaments Won: 1
Posts: n/a
Ive only pulled once so im far from being an expert.
Most guys (auto trans) were running in 2 low, nearly everyone pulling had either 410 or 373 gears with near stock tire size. I was running 3 low with 3.55 gears. If i shifted into 3 to early engine would bog, id kill my tire speed and pretty much look like a retard lol. I was boosing up to about 15 psi at the line (make sure you take tension out of the chain hooked to sled before you launch!), then launch, roll into throttle and by 50-75' down track it was wide open throttle. Dont be afraid to ask other pullers there what to do, many of them will gladly give you pointers.
Old 03-14-2007, 09:30 PM
thanks man. . .yea i figured low 2nd would be the gear of choice how long did you have to sit to get her up to 15 lbs lol sweet sponsors by the way i wish knew someone with connections on mods for the ol stroker
Old 03-15-2007, 08:40 AM
lukecline
Tournaments Won: 1
Posts: n/a
It didnt take long to spool up to 15 psi, basically all you do is hold your foot on the brake and ease into the throttle until the rpms come up enough the turbo starts making boost. I didnt pick up any sponsors until i got the truck into the 12's, so i had already dealt with all these guys . I started at the bottom like everyone else and worked my way up.
Old 03-15-2007, 10:47 AM
99Smokin73Stroker 99Smokin73Stroker is offline
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Just be careful, when you're done...you're done. Guys often try to squeeze out an extra inch or two and end up breaking parts.
Old 03-15-2007, 02:53 PM
thats a good thing for me to remember thats the last thing i need is to breakin everything
Old 03-15-2007, 03:50 PM
lukecline
Tournaments Won: 1
Posts: n/a
Ive also heard that if you air your tires down to get more traction your risk of breaking stuff increases greatly (makes sense to me). I left my rear tires up to 70 psi and aired the fronts down to 40 or so.
Old 03-15-2007, 06:32 PM
squeeks squeeks is offline
anybody on here pull with a 5spd, if so what gears do you guys run?
Please specify tire size, rear end too. Thanks
Old 03-16-2007, 05:13 PM
DirtyDiesel DirtyDiesel is offline
prolly shouldnt tell my secrets but wat the hey... i air my 36's down to 20 in the front and 30 in the rear and for the pulling part i have it in 4-lo and start off in 1st gear and just mat it, i tried to spool up befor ei took off but the truck just goes the brakes wont hold it, but soon as i take off with it firewalled i watch my tach and soon as it redlines i slam er in second and hag on... when im pullin(and my turbo isnt burnt out like it was at the last pull) im spinnin my motor around 3200rpm and got plenty over 35psi of boost. i havent tried to go to drive yet but im anxious to see wat it does. hope this helps ya out for you first pull.
hey hope your not gonna be pullin in florida now that i gave you all my tips
JK.
Old 03-16-2007, 05:31 PM
720Deere 720Deere is offline
JK.
Probably not, but I'm sure there's a little red powerstroke listening!
