Need H2E Turbo Parts/Info
I know its been a while since I posted but:
We attended a Pull in Lebanon TN last night with out 2.5 puller and ran into some problems. As the driver came out on the clutch the turbo seems to have took a dump. Shaft broke, compressor ate itself, and Im sure the turbine did the same but don't have it off yet to see. This was only the third pull on this charger, and I am 99% that it happened due to a malfuntion in the oiling system, and it just ran dry. But anyways...I need to know where I can get some parts kinda quick. I would like to have the truck pulling by next weekend if at all possible. I may rebuild my current center section or buy another one, just whatever I find. Is there a good builder for these H2E's around? Where to buy wheels, shafts etc? Are there any upgraded wheels available?
My turbo had the 17cm housing which I need to stick with because anything more we would have problems staying on top of it (see below). Are the turbine wheels the same between the 17, 19, and 22 cm housings? I have heard of people taking the larger turbine of the 22cm and machining the 17 housing for it, so the spool is great. Is there any truth to this, or are all the wheels the same? I might be interested in this, just so we can stay on top of the charger in a higher gear.
I know you guys are all thinking what kind of puller: Its a Dodge 12v, pretty healthy, and we normally pull in 2.6 with a S400 based charger, but for the 2.5 pulls we bolt on the H2e and go play. And low and behold our next 3 pulls are 2.5" class.
When I get the turbo off the puller, I will be sure to post pics of the carnage, I think it will make most of you go oh Chit!
Any help is appreciated!!!!
