Scosche Industries
Scosche Industries |
Scosche HD Amplifiers
Scosche HD Amplifiers HDA4002 - 400 Watts Max 2-Channel Amplifier $99.95 ![]() HDA8004 - 800 Watts Max 4-Channel Amplifier $129.95 ![]() If you're in the market to boost your audio system, check out Scosche HD amplifiers. Scosche HD is designed for value without compromising sound quality or components. The HD amplifier line-up includes 2 amps. The 2-channel 400 watt amplifier (#HDA4002) boasts a 50 watts RMS x2 at 4 Ohms power output. The 4-channel 800 watt amplifier (#HDA8004) has 50 watts RMS x 4 at 4 Ohms power. Features -Thermal overload protection -Sturdy Aluminum Side Panels -RCA and high level inputs -Brushed Aluminum Heatsink and Top Plate -Dynamic bass boost Last edited by ScoscheCarAudio; 12-14-2012 at 10:50 AM. |
Arriving Spring 2013! ![]() Scosche HD 5-Channel Amp & HD Mono Amp The two new HD amplifiers both feature Class-D topology, thermal overload and short circuit protection, variable crossovers, MOSFET switching power supplies, RCA and speaker level inputs, brushed aluminum heatsink and top plate and dynamic bass boost. In addition, the 5-channel amp and MONO amp have a bass knob included. The new 5-channel amplifier (#HDA5CHANNEL) is the first all-digital amplifier under $300.00. It’s full-range channels boast 50 watts RMS x4 at 4 Ohms while the subwoofer channel outputs 250 watts RMS at 2ohms for full system power. It also features a separate front and rear input summing, remote bass control port, and selectable gain range. The 500 watt mono block (#HDA1001) outputs 500 watts RMS x 1 at 2 Ohms and is a full-featured mono amp for under $200.00. It features a power protect indicator, speaker level input and remote bass control port. Both amps will be available for purchase by Spring of 2013. |
