S&B Filters
S&B Filters |
S&B intake install
This is the install of S&B's new updated Air Intake system for the 2008-2010 Ford 6.4 Powerstrokes. As some know I am doing a test for them on the Blue OX and as part of my test I am posting an install with my my opinions.
So on with it then. Obviously the first step is too remove the factory intake. Start by removing the filter-minder. Be sure to keep the rubber grommet that it plugs in too as a new one is not supplied. ![]() Unplug the Mass Air Sensor at this time and undo the large hose clamp behind it. ![]() Pull up hard on the air box and it will pop out of place. No hidden bolts at all. ![]() Unscrew the hose clamp attaching the intake piping to the turbo inlet and on do you CCV hose and remove pipe ![]() Remove the mass air sensor and the filter minder grommet from the factory air box. You will need a hallow 6 pointed bit (size escapes me) to remove the sensor. Unfortunately one is not supplied to remove them. ![]() A new gasket, screws and tool are supplied to mount the sensor in the S&B pipe ![]() Install the bottom half of the new S&B box in the space left by your old box. ![]() Make sure it is aligned with the air inlet in the bottom and is seated in the mounting grommets. ![]() Locate the new S&B turbo inlet to pipe adapter boot and respected hose clamps ![]() Take the adapter boot and new section of pipe and loosely assemble. Do not tighten anything yet. ![]() At this point you need to reattach your CCV line or commit to the CCV mod as I have done. That is another subject though. ![]() Reinstall the filter minder grommet in the new S&B piece. ![]() Take your filter and fit it to the S&B upper box piece. ![]() If you have a filter cover install it now also. ![]() Locate the S&B coupling boot and respective hose clamps and install on the upper box piece. ![]() Attach to the pipe running to the turbo. ![]() Set the upper box piece on top of the lower box piece and reconnect the sensor and filter minder wires. ![]() Locate this rubber piece ![]() And install in the side of the box. ![]() Peal the protective paper off of the clear box cover and use the supplied hardware to attach to the box. ![]() At this time go back and make sure to tighten everything up and make sure everything is properly fitted. Then take a step back and admire. ![]() Overall I feel that this is a very well designed and built product and the install was very easy. Anyone can do this and I feel that that in itself is a great selling point. With the exception of not having a driver bit for the Mass Air Sensor screws I feel that this an extremely complete and well thought out kit. Thus far I am very happy with it. I will update every one on my driving experience with it in the coming weeks. |
Thorough review here, Ryan.
I look forward to seeing your results, the big girl is still under factory programming, right? |
Yes its still all factory. I waiting for someone to send me a tuner and exhaust to test out.
Ryan your Truck looks Amazing. I have a new to me 08 F450 and I was wondering what you did with your caps on front and hear. those look great. thanks ahead of time
Caps? WHICH CAPS?
I bought a used s&b intake for the 6.4 and my intake has a flange the bumps out by the battery where yours is flat. Also I do not have A rubber piece to cover up that opening by the battery like you do. Do I just have an older style or something? Any help would be appreciated.
Yes you have the older one. This one is the updated version of yours.
