1992-2009 F-series Super Bright CREE LED Reverse Bulbs - Ford Powerstroke Diesel Forum
Retro-Solutions
 2Likes
post #1 of 589 Old 05-01-2013, 02:42 PM Thread Starter
retrosolutions's Avatar
Quoted: 30 Post(s)
Super Bright CREE LED reverse bulbs specifically fitting 92-09 Ford Trucks!
*Note: may exclude some models with different fixtures/sockets (other fitments available)
only $32.99 /pr!!!
NEW VERSION
BRIGHTER and WIDER TOTAL OUTPUT than previous versions
UNLIMITED RUN TIME, TEMPERATURE COMPENSATED
To place an immediate order, CLICK HERE
- 6x CREE XB-D series technology LEDs (R5 binned!)
- very wide and bright 360 distribution
- focusing lens and side firing LEDs for excellent coverage
- self compensating for running temperature
- Fits stock location, just pop it in
- Works in any 8-18v vehicle/socket
Currently $32.99 per pair!
Each bulb consists of a 6 LED array using CREE's latest generation X-Lamp series. These LEDs pack a very big punch in a very small package, with excellent luminous efficiency, and advancement in thermal transfer.
Each bulb totals more than 875 Lumen of directed light output at maximum output. That's more than twice the output of the stock bulb they replace.
Now only $32.99 /pr!!!
Some real customer example photos:
Just the CREE LED bulbs:
CREE in comparison to the Stock bulb on opposite sides:
No reproduction, re-posting, or copying of images, text, or other media allowed without contractual permission
Retro-Solutions, LLC 2013 All Rights Reserved
Mon.- Fri. 9am-4-pm Eastern time
(860) 406-4443
retrosolutions is offline
post #2 of 589 Old 05-08-2013, 08:07 AM Thread Starter
Quoted: 30 Post(s)
Here is a customer's Dodge Ram truck for example:
New CREE vs. Stock
New CREE
(860) 406-4443
post #3 of 589 Old 05-08-2013, 09:22 AM
buckels's Avatar
Send a message via AIM to buckels Send a message via MSN to buckels Send a message via Yahoo to buckels
So we dont need resitors or anything? Just plug and blind... I mean play?
john galt likes this.
Drew
99 SD 6SPD manual
AFE Intake
Diamond Eye 4" turbo back exhaust
Wicked Wheel Gen2
PHP Hydra tunes by Bill
If you live in WA or OR check out these links.
buckels is offline
post #4 of 589 Old 05-08-2013, 09:24 AM Thread Starter
Quoted: 30 Post(s)
LOL! Yes, that is correct, they just plug in place for reverse bulb sockets using 3156, 3157, 4114, 4114K, 3047, 4057, 4157... etc. type bulbs.
(860) 406-4443
post #5 of 589 Old 05-08-2013, 09:34 AM
Quoted: 2 Post(s)
Where do these ship from? Cause CREE is about 45 minutes from me, are you in NC too where local pickup could be arranged?
Troy K.
2003 Ford F-250 6.slow w/240K
4" Turbo back exhaust
SCT X4
XDP coolant filter
Blue Spring
315/75 BFG MT's on American Racing rims
Leveled
5100's
And way more time and money invested than its worth
Turk.919 is offline
post #6 of 589 Old 05-08-2013, 09:38 AM Thread Starter
Quoted: 30 Post(s)
We are located in Connecticut, so a bit far for local pick-up!
CREE is only the manufacturer of the specific LEDs used in the product, they do not make the bulbs themselves. Manufacture of the bulbs is here in CT.
(860) 406-4443
post #7 of 589 Old 05-08-2013, 09:58 AM
buckels's Avatar
Hmmmm tempting....very tempting
Drew
99 SD 6SPD manual
AFE Intake
Wicked Wheel Gen2
buckels is offline
post #8 of 589 Old 05-08-2013, 10:18 AM
DoubleDpsd's Avatar
Is this an updated bulb or something cuz last time I asked and checked I was told something has to go in line in the wiring to prevent a hyper flash turn signal light on the dash??
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #9 of 589 Old 05-08-2013, 12:44 PM Thread Starter
Quoted: 30 Post(s)
It is a new version bulb, but it is for REVERSE lamp use only, and in a few makes/models of vehicle maybe daytime running lamps. These are not designed nor intended for turn signal use.
(860) 406-4443
post #10 of 589 Old 05-22-2013, 02:38 PM Thread Starter
Quoted: 30 Post(s)
All orders shipped, and production is finally up to levels allowing for stock on hand now!
(860) 406-4443
