7.3 staring problems - Ford Powerstroke Diesel Forum
Powerstroke.org Site Problems Let us know if you are having any site issues here!!
Old 06-14-2012, 12:48 PM
I have a 1999 f 250 with 234000 miles I replace the water pump and radiator I try to star the truck before I put antifreeze it star for about 5 sec then it die and it didn't star after that any idea of what is wrong with it
Old 06-15-2012, 08:40 AM
starting
did you dry start it with no water or antifreeze?
Old 06-19-2012, 10:06 PM
Yes I did and it run for about 5 sec then it didn't start after that
Old 06-20-2012, 02:41 AM
oh....
I'm no expert but I would presume it is seized up due to overheating
Old 06-21-2012, 05:33 PM
will it still turn over?
Old 06-26-2012, 05:11 PM
iYes I spray some staringfluid and it started for about 3 sec and it die again I didn't want to do it again because they say staring fluid its bad for ur motor
Old 06-26-2012, 05:22 PM
You'd think there was still enough fluid in the block to not really damage much.
1. Does it crank like it normally did before?
2. Do you get a WTS light with the key on?
Old 06-27-2012, 02:44 AM
It cranks normal like before
Old 06-27-2012, 02:46 AM
It cranks normal like before makes me wonder if that fuel pump wen bad
Old 06-27-2012, 04:10 AM
Ok.
Does the WTS light come on with key on?
When the key is turned on and the fuel filter is out of the bowl, does it fill up with fuel?
After cranking a bit, is there still oil in the HPOP reservoir?
