| Powerstroke.org Site Problems Let us know if you are having any site issues here!! |
1999 7.3 diesel
runs rough at idol but after it warms up it idols fine but when igo to give throttle and hold it at 2000 rpm itslowly dies on its own i changed fuel filter fuel heater fuel pump and camshaft sensor what would be next.
Post under the 1999-2003 7.3 problem section. Nobody is gonna see you here.
Possilbe fix
Try the relay or glowplugs. Can be typical for 7.3's or any diesel.
Need to be able to check hpop pressures when it's dieing. Fuel pressure readings too
For the idiling when driving check one of the turbo valves, could be stuck shut.
