7.3 replace 6 litre ??? - Ford Powerstroke Diesel Forum
Powerstroke.org Site Problems Let us know if you are having any site issues here!!
Old 02-09-2010, 05:54 PM
Can you replace an 03 6litre in a F250 with a 7.3 And what is involved ??
Old 02-09-2010, 05:59 PM
wriott
Guest
Posts: n/a
LOTS!!!! basically everything to make the engines run need to be swapped out... wireing harness. computer, IDM, ect.... then change the crossmember because the motor mounts are different... also have to change drivetrain... trans, driveshafts, transcase, ect....
Old 02-09-2010, 06:06 PM
Can you buy a converter wiring harness ???
Old 02-09-2010, 06:11 PM
wriott
Guest
Posts: n/a
nope..... they make kits for puttin a cummins in...
Old 02-09-2010, 06:15 PM
Where do you find a kit and what year cummins fit ?? Do you have to change the tranny ???
YOu would be better off kepping the 6.0 or doing a Cummins swap.
Old 02-09-2010, 06:19 PM
wriott
Guest
Posts: n/a
there are lots of places like... destroked.com, and others i cant think of right now... do a google search. you can use the stock trans or switch to another trans
Old 02-09-2010, 06:30 PM
thanks for the info...
