Ok guys I have and early 99 f250 7.3l. I'm soon going to be buying a TS 6 position chip. I've seen a couple of guys running a Boost relief valve. I'm just wondering if the BRV is going to be this necessary. Any info on brv or how to run a DIY setup would be much appreciated!
I'm not quite sure what your referring to. There is a blow off valve the can be added for $600 but is completely unnecessary. Then there is a waste gate actuator. The stock one is fine.
If yiur getting a chip. I suggest quality gauges, intake, and exhaust. And if your an auto. Get a 6.0 Trans cooler.
Talk with Corey@CNCFAB and get the ts6 chip with php tunes
Ok, I have a 4in turbo back straight pipe. I'm referring to the defueling the PCM will do once it passes the 25psi mark. Without the BRV it will through the SES light right?
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
