Originally Posted by SoCalGlide
IDK, if this engine puts out that kind of power, is cheaper in both initial and operating costs than a diesel, I'd have to consider it. I've got a diesel to pull my 15K trailer. If this gas/E85 combo does a better job of it, I'm on board. It's about working smarter.
Unless they can guarantee this engine will have the longevity of a diesel and can handle the work load of a diesel, I don't see it taking a diesel's place. There is a reason why there are virtually no gasoline ambulances. They just can't take the abuse that an ambulance dishes out. I have had two gasoline ambulances, and neither made it to 150K miles before the engines were completely shot. Burned valves, washed cylinders, bad crank bearings, you name it. It's from spending half their lives idling. It's just the nature of the job. You can't beat a diesel for this sort of work.
I think a lot of other commercial fleet people will agree with me. I know the oil field companies around here use exclusively Ford and Chevy diesels. Mostly Fords. They get as much or more abuse from their crews than ambulances. They also spend 50% of their lives idling. My ambulances average 13.7-23.5 miles per hour over their lives. That's a lot of idle time. I just don't think that a gasoline engine is going to handle it.
