Go Back   Ford Powerstroke Diesel Forum > Powerstroke.ORG News and Polls > Powerstroke.ORG News
Powerstroke.ORG News News related to Ford Diesels as well as site news. Only Administrators may create new threads in this section.
  #151 (permalink)
Old 06-08-2009, 05:18 AM
bigwhite7.3stroker bigwhite7.3stroker is online now
Florida Stroker
damn Scott thats quite a list but at least she made it to the end
  #152 (permalink)
Old 06-08-2009, 09:17 AM
RHCDIESEL RHCDIESEL is offline
May i suggest some 3/4 inch bolts or weld your ladder bars back on,those 1/4 or 3/8 bolts are too small for your Big A$$ truck
  #153 (permalink)
Old 06-08-2009, 09:22 AM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
thats fixed , that was the easy part
  #154 (permalink)
Old 06-08-2009, 09:51 AM
Austinj427 Austinj427 is offline
You really meant it when you said you built her for the pull. That thing must have hooked pretty hard to break all that stuff especially being down on power.
  #155 (permalink)
Old 06-08-2009, 09:57 AM
01excursion7.3 01excursion7.3 is online now
well, from whats been said, him being down on power is like us normal guys trucks running like raped apes! Don't really know if you can actually call it down on power. LOL
  #156 (permalink)
Old 06-08-2009, 04:03 PM
ABOBB ABOBB is offline
Is it even worth it???
Originally Posted by SCUFFY828 View Post
well tore the truck down yesterday , oh my god , i really tore some crap up,
heres the list :
trans slipping
rear driveshaft and flange busted
rear pinion gear broke in half, and rear end flange broke
rear locker damaged from pinion gear
both front axles broken completly off at hub
both 4x4 hubs shattered like a grenade
ladders bars ripped from frame , and mounts on rear end bent
anybody care to doante some parts jesus christ
I'm sorry... but you did tell me you wanted it to hook up!!! Truck had all the necesary parts, just a couple of key pressure settings and I knew it was probably gonna break somethings, especially since it was the last event.
  #157 (permalink)
Old 06-08-2009, 10:25 PM
Hardline Hardline is offline
Scott did you feel which went first the front or the rear? Sounds like one popped and just sent all the force to the other axle. What kind of front shafts were you running. I have heard good things about the Bobby Longfield Cvs that he came out with for the 60s. I have always run Superiors though. On the hubs I would probably stick with Warn Premiums. Not the strongest option but I do not think you want drive flanges on a street rig. Although may be a good option for nest time while hooking to the sled. JJ
  #158 (permalink)
Old 06-09-2009, 04:41 AM
the ladder bar bolts broke, twisted rear end, snapped pinion gear in back, then all pressure went to front and snapped axles and hubs
  #159 (permalink)
Old 06-13-2009, 11:53 AM
well she is back up and running , time to work on the starting problem , woo hoo , at least i can drive it
  #160 (permalink)
Old 06-13-2009, 01:27 PM
mudrunninpig mudrunninpig is offline
D80 Axle Snapper
Glad she is back together
