96 7.3 new injectors and has a miss under acceleration - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-02-2014, 04:29 PM Thread Starter
hey guys im a long time reader but a first time poster. I have done extensive searches and research before posting. I have a 96 powerstroke with 167xxx miles. 3 inch down pipe to a 4 inch exhaust. afe intake. 6.0 trans cooler, tony Wildman tunes and gauges. I have recently installed a set of remanufactured stage 1 160cc single shot injectors by rosewood diesel. at the same time I also replaced all the uvch's and pig tails along with a fresh oil change with rotella 5w40 synthetic. once I installed and started I drove it as directed and it chugged like a miss under acceleration. I continued to drive it to get air out but no change after almost 200 miles. I have changed IDM and fuel filter with no change. I have also removed the valve covers and checked all connections and they were good and ensured that all injectors were spitting oil along with cleaning the ebp sensor and tube. I also cleaned the fpr screen. it idles fine starts right up but has a miss on acceleration until in the high rpms and than it runs awesome. I did a fuel pressure test and it bounces between 50-60 at idle and drops to and below 40 at WOT. it has gotten worse once I removed my chip (sent in to get reburned) and I am at a loss. would a weak mechanical fuel pump cause these strange symptoms due to it being cam driven? sorry for the long post but I figured more details are better than no details. thanks again guys!
oleary is offline
post #2 of 5 Old 08-02-2014, 08:08 PM
Quoted: 27 Post(s)
If you didn't tug on or replace the fpr spring and replace the o rings in there you're probably still losing pressure due to a weak spring or fuel leaking by the o rings. I would order the fpr rebuild kit from diesel o rings or grab one from Ford if you need it quick. If the pressure is bouncing 10 psi I'd put money its the fpr. Fuel pressure should be constant and not drop below about 60psi under wot. I had 58 psi at idle and dropped to 35 under wot. New fpr and I have 68-70 psi at idle and 60-62 wot.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #3 of 5 Old 08-02-2014, 09:02 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
I believe fords spec is anything under 45psi is unacceptable. But it should be in the 55-65psi range
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #4 of 5 Old 08-03-2014, 07:35 AM Thread Starter
Ah I see. I'll order that today. I'm gonna replace the mechanical fuel pump while I'm at it. Thanks for the quick replys!
oleary is offline
post #5 of 5 Old 08-03-2014, 07:38 AM
Quoted: 27 Post(s)
Let us know how it goes.
-Kris
4'' straight pipe
DIY 6637
38r
