truck problems - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-07-2014, 11:29 AM Thread Starter
truck problems
Hi all,I need some help with my 95' F250 7.3 powerstroke. First of all its has no power or acceleration,i am struggling to get 50mph,also not revving above 2500rpm on normal operating temp and therefore not shifing properly,a friend on the forum gave me some pointers and some info,what to check and what to do.I have checked the crank pickup,checked the tps(throttle pos sens on the pedal)measuring 180ohm to 2500 ohm,checked the boost pipes and found a rubber o ring that had a gap in it and replaced it,i have replaced the computerbox,i have replaced the fuelfilter and checked for loose wiring and connectorplugs,the engine is running and idling smooth,what could the problem be?no warning lights and no fualts on the diagnostics,i need help please as no one in SA wants to work on my ford.kind regards
jpelser is offline
post #2 of 7 Old 02-07-2014, 12:09 PM
ADMIN AND TECH
SCUFFY828's Avatar
need to run a fuel pressure test , also need to check and see if exhaust back pressure valve is staying closed
ITS STOCK
SCUFFY828 is offline
post #3 of 7 Old 02-08-2014, 09:15 AM Thread Starter
truck problems
thanx for the info,where is that valve located?is it on the turbo exhaust housing?how do i test it?what ese could be fualty?
jpelser is offline
post #4 of 7 Old 02-08-2014, 09:33 AM
sandrock1's Avatar
The valve is just on the down side of the turbo and it closes when cold out. You can always unplug the 2 wire connector at the base of the turbo and that will disable it from closing anymore.
sandrock1 is offline
post #5 of 7 Old 02-08-2014, 09:44 AM Thread Starter
thank u.the truck revs up now but still no power
jpelser is offline
post #6 of 7 Old 02-11-2014, 11:11 PM Thread Starter
Hi,stiil no luck in trying to fix my truck,I don't know what could be wrong,checked everything but fuelpressure,no one knows where to test it?any help would be gladly accepted!
jpelser is offline
post #7 of 7 Old 02-12-2014, 03:41 AM
sandrock1's Avatar
To test fuel pressure I think there should be a schrader valve just to the right of the fuel bowl. It faces towards the right. I believe that is the only place to test for the pressure.
