Truck problems - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-07-2014, 10:21 AM Thread Starter
Truck problems
Hi all,I need some help with my 95' F250 7.3 powerstroke. First of all its has no power or acceleration,i am struggling to get 50mph,also not revving above 2500rpm on normal operating temp and therefore not shifing properly,a friend on the forum gave me some pointers and some info,what to check and what to do.I have checked the crank pickup,checked the tps(throttle pos sens on the pedal)measuring 180ohm to 2500 ohm,checked the boost pipes and found a rubber o ring that had a gap in it and replaced it,i have replaced the computerbox,i have replaced the fuelfilter and checked for loose wiring and connectorplugs,the engine is running and idling smooth,what could the problem be?no warning lights and no fualts on the diagnostics,i need help please as no one in SA wants to work on my ford.kind regards
jpelser is offline
